Connecting to your WiFi network with Windows 11
Connect your Windows 11 computer to your Plusnet router with the help of our FAQs.
Windows 11 WiFi FAQs
You'll find both of them either on a sticker on the bottom or back of your router or on a pull-out tab at the back.
If you're connecting to the Internet using one of our routers, the SSID will look something like this: PlusnetWirelessABC123 or PLUSNET-Z258.
Your wireless password is made up of ten numbers and letters.
- Select the Network icon on the far right of the taskbar to open quick settings.
The Disconnected icon will show when you’re not connected.
![](http://static.plus.net/content/dam/plusnet/images/help/broadband/how-to-connect-to-your-wi-fi-windows-11/disconnected-windows-11.png)
- On the WiFi quick setting, select Manage WiFi Connections >
![](http://static.plus.net/content/dam/plusnet/images/help/broadband/how-to-connect-to-your-wi-fi-windows-11/manage-wifi-connections-windows-11.png)
- Then select the > icon next to the WiFi quick setting to see a list of available networks.
Choose the WiFi network you want to connect to, then select Connect - Type the security key (often called the password).
Remember, your password is case sensitive so if you're having problems, double check what you're typing. - Follow additional instructions if there are any.
![](http://static.plus.net/content/dam/plusnet/images/fragments/need-more-help/desktop-need-more-help-4.png)
More ways to get help
![](http://static.plus.net/content/dam/plusnet/images/icons/grey/64/64-grey-community.png)
Plusnet community
Talk to our community
![](http://static.plus.net/content/dam/plusnet/images/icons/grey/64/64-grey-mono-support.png)
Contact our team
Or call 0330 1239 123
![](http://static.plus.net/content/dam/plusnet/images/icons/grey/64/64-grey-accessibility.png)
Sign Language service
Contact us using British Sign Language
![](http://static.plus.net/content/dam/plusnet/images/icons/grey/64/64-grey-mono-v2-user-customer.png)
My Account
Sign into Broadband
Sign into Mobile
